Refrigerator getting too cold
Whirlpool side by side with bottom drawer freezer
Just over year old
Fridge getting too cold
Have tried unplugging electrical
Reset to factory setting
Fridge set for 38 degrees F
Ideas???
Replacement parts for WHIRLPOOL GI7FVCXWY02 REFRIGERATOR | AppliancePartsPros.com
Run the diagnostics to see if a problem will show up.
The damper and the fridge thermistor would be at the top of the list.
The damper regulates the amount of cold air that enters the fresh food side.
Also put a thermometer in the freezer to see its actual temperature, should be between 0 and 5 degrees F.
Would not hurt to get an actual fresh food side temperature.
Have you tried unplugging the unit for a couple minutes to see if it will reset?
If the diags run OK then you may want to get a pro in ads this is a complex unit and unless you have a meter and some experience it will be difficult to troubleshoot.
G17FVC.pdf (594.4 KB)
