Refrigerator Frozen, Freezer Extra Cold!
Hi guys,
I have a Kenmore side by side fridge that I assumed had a bad baffle (fridge would on and off start to freeze as the temperature in the house warmed up at the change of seasons, thought maybe it was freezing). However, today I popped a thermometer in teh freezer and the temperature is ~-15F (fridge is at ~30F) - I think the thing is running on overdrive!
Anyway, I’m guessing it’s a thermistor or main board? Can anyone weigh in? If so, where are they located and how can I check? I tried to use the diagnostic mode using the front control panel, but I think one of the buttons is bad as I cannot get it
Nick K.to access diagnostic mode, so assuming I’ll have to fix it the old fashion way.
Thanks,
Hi guys,
Checking in again to see what you guys think.
The problem went away for a couple weeks, and just this weekend everything is frozen again in the fridge.
