Brand: Frigidaire
Model Number: FPHC2398 LF3
Main Symptom: no light in fresh side
The refrigerator is a 14-year-old Frigidaire. The light does not turn on in the fresh food compartment, while the freezer light does turn on. The door switch is OK. I checked it: the switch is good and power is present at the switch. The bulbs are also OK. The bulbs are not LED type.
I ordered a control board (part number listed above). I selected a compatible board using the parts lookup on an appliance parts website. After installing the new board, neither the compressor nor the refrigerator starts, and the freezer light also does not turn on. At the same time, when the original board is installed, the light turns on and the refrigerator works normally, except for the fresh food light.
What could be the issue? Is this the wrong part, or is the replacement part defective?
Thank you.
Parts or tests already tried: control board 5304498781
