Brand: Model Number:253.44743110 Main Symptom: Freezing Food What happens & when:Can’t control the temp.
Error Code (if any): None
Parts or tests already tried: door seal, fan. I need location of temp sensor. This unit has no freezer. Refrigerator only.
The thermistor for a stand-alone refrigerator is commonly found either on a side wall or the back wall near the center of the appliance, or it would be found in the control housing. This link can be used to view what the thermistor should look like, as this style is commonly exposed instead of being hidden behind a thermistor cover. Frigidaire 297110400 Refrigerator Thermistor Temperature Sensor | Genuine OEM Part
