I have a GE refrigerator that quit working yesterday.model tbx21jax
it does not kick on.when i turn it on is just making a little noise,it looks like it lost the power.is not working at all,its just making some noise.
do you have some help for me?
Replacement parts for TBX21JAX models | AppliancePartsPros.com
First find out what the noise is.
What is running and what is not.
If the condenser/compressor fan is running then the compressor should be running.
I think but cannot confirm this as I do not have a wiring diagram.
The second link above has good info on how to check the compressor overheat and start relay.
Following are a couple good links on basic fridge repair.
http://www.applianceaid.com/frig.html
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Look under the unit in the machine comartment and behind the kick plate for the wiring diagram.
It is a GE so getting any tech info off the net on it is very difficult. GE likes to keep everything a secret.
