Door to refrigertor door stopped closing a few days ago. Nothing obstructing the door and gasket around door looks fine. It seems the problem is coming from where the door rotates on the bottom of the door. Any help is greatly appreciated! ![]()
Fresh food section replacement parts for GE TFX24RFB | AppliancePartsPros.com
Sounds like one of the cam risers may be broken.
These help hold the door shut.
Item 16 in the “Door Parts” section and Item 451 in the “Fresh Food” section.
Looks like Item 451 comes with both cams.
That is the one I would use if either either is broken.
