The refrigerator door makes popping sound when opening and closing
The refrigerator door makes popping sound when opening and closing the door
Hi, John.
In your case the problem is, most likely the worn out door cam(s). They are located at the bottom of the door and on the door hinge. Replace both of them at the same time.
The door cam for your model is AP6005980.
The part number for the kit is AP3103517.
If you click on the first part you will be able to watch the video with installation instructions.
If you’ ll have any questions, please let me know.
Thank you.
Simon.
