Refrigerator cools and freezes and then stops
Brand: fridgeadar
Model Number: frs6hr5hb6
Main Symptom: will not keep cooling or freezing
What happens & when: runs and cools and freezes then stops and if i unplug it and replug it is runs like normal for a day and then stops cooling
Error Code (if any): none
Parts or tests already tried: replace run capacitor and start relay. compressor runs and cooling fans running
Based on the information provided the control board is likely the issue and would need to be replaced.
https://www.appliancepartspros.com/repair-help/
