Brand:Amana
Model Number:ART318FFDW03
Main Symptom:Food in RC freezing
What happens & when: Daily
Parts or tests already tried: Followed previous instructions provided on this forum: “Is the freezer evaporator covered in thick frost or ice? If not Check the thermistors RC & FC. if they check good replace the Athema Control board. If thermistors check bad then replace the bad part.”
There was a large ice block at the top of the evaporator that also enveloped the FC thermistor. The FC thermistor itself was functional (as was the RC) so we replaced the control panel. However, freezing resumed immediately. Now what?
