Brand:kenmore
Model Number:253.44723100
Main Symptom:does not cool
What happens & when:works for 3 days
For Kenmore 253.44723100, the fact that it cools normally for about 3 days and then stops cooling is a very useful clue. I would not start replacing sealed-system parts yet. First determine whether you’re dealing with an evaporator icing/defrost problem or whether the compressor stops running.
Quickest test — check the evaporator
The next time it stops cooling, do not unplug it yet.
Remove the freezer’s inside rear panel and look at the evaporator coil.
- Coil buried in heavy white frost/ice: You have a defrost failure. Check the defrost heater, defrost thermostat/bi-metal, wiring, and defrost control.
- Only one small section of the coil has frost: Suspect a sealed-system/refrigerant problem.
- Coil has a light, even frost pattern but isn’t cooling: Check evaporator fan operation and airflow.
- Coil is basically dry and the compressor isn’t running: concentrate on the compressor starting/control circuit.
Important clue
If you unplug it long enough for all the ice to melt, plug it back in, and it works perfectly for another 2–3 days before warming again, that’s almost textbook evaporator icing caused by a defrost-system failure.
When it’s failed, also listen at the compressor. If the compressor is hot and repeatedly clicking every few minutes, check the compressor start device/overload. If the compressor is running continuously but the evaporator has little or no frost, that’s when I’d start suspecting the sealed system.
If you can tell me whether the freezer rear wall gets covered in frost when it quits, I can narrow this down to the next component/test.
