My refrigerator is blowing warm air. Whirlpool Mark I series. Model #: EHB191MKWR0
Turned the device on and off. Fan is running.
Thanks.
Replacement parts for Whirlpool EHB191MKWR0 | AppliancePartsPros.com
Confirm that the compressor is running.
You can usually hear it but it should also be warm and you should be able to feel it vibrating.
If on remove the cover in the freezer so you can inspect the evaporator coils.
If there is no frost on the coils you have a sealed system problem and it will be an expensive repair as you need a pro.
Often it makes more sense so put the dollars towards a new unit.
