refridgerator door wont shut all the way unless you push on it and when you open freezer it pops open…once pushed shut will pop back open after a while…water is condensing inside the fridge all the time and i dont knwo what to do…the frige is only around 2 years old or less. cannot find the warranty papers on it..what do i do?
If the gasket is in good shape and mounted properly, duck tape the door shut till the gasket seats properly. Do this overnight, should be fine in the morning.
