refridgerater freezing everything
I set the temp at suggested temp and just keeps getting colder freezing vegetables first won’t regulate what should I do!?
You will need a meter to check your thermistors, or just replace all the fresh food thermistors, one at the damper and another one at the bottom if your fridg has one.
