Hello,
Ref - GE Profile Range Model No. PS950EF3ES
Triple Inner (Smallest) Burner Not Working!
Had replaced multiple times with new Triple Burner from 3rd party & OEM (GE) and each time inner most burner not working.
What should I be looking for to correct this anomally?
Thank You Jim B
JimBAgde, with the power cord unplugged, the wire going to the inner triple burner would need to be checked for any damage and tested for continuity. If the wire is good, the failure would be in the burner relay control. GE WB27T11357 Frame Board Asm (AP5790964) - AppliancePartsPros.com
