Red light is blinking on the Ice Maker Control and no ice is being made. Water dispenses fine from door dispenser and motor runs on ice dispenser. What do you think the problem is? I am hoping it is a simple fix that I can do myself!
Hi.
What is the status of the LED?
If it blinks twice followed by one blink, close the flapper door on the left and check the status again.
If it’s the same (2 blinks followed by a one) - replace the optic control boards AP5956767
Here are the breakdown diagrams and Freezer Liner parts for Whirlpool KSRA25ILSS03 - AppliancePartsPros.com
Post the results.
Simon.
Hmmmm. It blinks twice continuously. When I close the flapper I get a solid red light, no blinking. Thanks for your response.
Hi.
The optic control is good. Pull out the fridge,take the bottom panel off, remove the water valve.
Switch around the electrical plugs on the valve (you may need to hold the right side to make connection or use jumper wires) and have someone push the water lever at the dispenser. If the valve is good the water will go into the icemakerand that will indicate that the icemaker is bad.
If no water - replace the valve AP5263471
The icemaker AP3182733
Simon.
[quote=Simon / APP Team;795283]Hi.
Simon.[/quote]
When switching the electrical plugs on the valve, they aren’t the same size, so how do I connect the larger male side to the smaller female side? I don’t want to push too hard and make the female side too wide?
Please advise the best way to do this, without the jumper…thank you very much btw..this post has been the best answer to my problem. Now just hoping it’s one of these two issues! lol.
Hi.
The best if some one can help you holding the valve. If not then install two jumpers.
The door should be closed.
Simon.
Thank you.
Simon.
Hi Simon. Thanks for posting these troubleshooting tips! I was able to test the valve out as you described by switching the feeds from the water dispenser. We heard a hum when the water dispenser was pressed in and attached to the ice maker solenoid, but no water entered through the tube at the top of the freezer into the ice maker.
I was able to replace the valve and performed the flush routine on the water dispenser, but still have not yet been able to verify any water entering the ice maker and after doing the trick to use the water dispenser to kick off the ice maker solenoid, no water is entering the tray from the tube sticking down from the top of the freezer.
What do you think?
Thanks,
Bob
[QUOTE=bwatters;914926]Hi Simon. Thanks for posting these troubleshooting tips! I was able to test the valve out as you described by switching the feeds from the water dispenser. We heard a hum when the water dispenser was pressed in and attached to the ice maker solenoid, but no water entered through the tube at the top of the freezer into the ice maker.
What do you think?
Thanks,
Bob[/QUOTE]
Hi. It sounds like the ice maker water inlet tube is frozen. You need to melt the ice. You can pull the line out or get to it from inside with a blowdryer. Keep the new inlet valve installed, most likely the old one was dripping water.
Thank you.
Simon - thanks for the lightening fast response! I found this forum while searching the 'net for helpful resources. It’s people like you that keep this thing going. We really appreciate it.
I’ll see if I can play with the water supply to make sure the line isn’t frozen. Getting the tube back in place after pulling it sounds pretty tricky. Trying to heat it up with a hairdryer sounds like a good first move. Thank you!
I just heard that magical noise - ice cubes dropping! The line was indeed frozen. I was able to use a metal BBQ skewer to grind away at the plug until I saw dripping water. Nothing happened for a few hours and I wandered off to put the kids to bed and a moment ago I heard the noise I hadn’t heard in a while…
Thank you! This forum, the how-to’s and the parts service you all provide are invaluable!
