Brand: LG
Model Number: 410PNBM78245
Main Symptom: Will not drain
What happens & when: will not drain
I chatted with AJ who suggested I come here to confirm whether or not this part number would work with my LG washer, as per the conversation…“It appears AppliancePartsPros doesn’t list the circulation pump under your specific model, even though LG uses the part on compatible models. This can happen when the manufacturer’s model compatibility list isn’t fully populated. However, I suggest confirming that part to our repair forum to see if that part is really compatible with your model.”
The part number he originally recommended is: Recirculation Pump Assembly: 4681EA2001N
Then he recommended this part #: Lg EAU61383503 Circulation Pump Motor OEM Part
Then he recommended this part #: Washer Drain Pump Assembly (AP5676608), $216.78
I am looking for the correct parts to order to replace both the drain pump and recirculating pump for my LG washer model 410PNBM78245. There are no numbers listed in ( ).
Thank you.
