Brand:
Model Number:
Main Symptom:
Subject: Incompatible Control Panel Assembly Received – DG34-0002
7B for NX58H5600SS/AA
Hello,
I am writing regarding a control panel assembly I recently purchased directly from you.
Part number: DG34-00027B
Range model: NX58H5600SS/AA
This part was listed as compatible with my range model. However, after carefully comparing it to the original control panel assembly removed from my stove, I discovered multiple physical and functional mismatches that prevent proper installation and operation.
Issues observed:
Flexible printed circuit (ribbon) is shorter than the original part and does not reach or seat properly in the control board connector.
The contact end of the ribbon is oriented backwards compared to the original, making correct electrical contact impossible.
The ribbon is thinner and does not fill the connector width, resulting in a loose fit that cannot be secured properly.
These differences are not related to installation technique, as the original part and connector orientation are unchanged.
Because the electrical contacts do not align or seat correctly, the part cannot function safely or reliably in my appliance.
Req
Confirmation that I received an incorrect or incompatible variant, and issuance of a correct replacement, or a refund or exchange, as the part received does not match the original component removed from the range.
I have photographs available showing a side-by-side comparison of the original and replacement parts, including ribbon length, thickness, and orientation.
Please advise on the next steps. I would appreciate prompt assistance, as this issue currently prevents normal oven operation.
Thank you for your time and support.
