All burners on my electic stove do not heat. The red indicator light comes on but no heat. Have made sure all burners are connected right.
Replacement parts for Frigidaire FDB751SCS0 Frigidaire/dishwasher | AppliancePartsPros.com
Does that include the stove top and oven elements?
If yes then odds are you have a power problem (no 240 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
