The error code on the display is F3; the temperature sensor appears to be fine readings were within ranges specified. The values were the same at the hardwired connector in the harness as well as on the connection located on the timer control baord.
I can not seem to find a service manual for this model, nor the schematics for the control board. The stove top still functions normally.
It says F3 is a sensor problem so start there.
Here is a link with sensor info, check out 7, 8, 20 and 21 http://www.applianceaid.com/elecrange.html
Also check that the connectors are clean and they are properly soldered to the board.
Be sure to unplug the unit when working on it.
Also here is a site with many manuals and you may be able to find one that is a close match to your unit. ApplianceDigest.com - Appliance Repair Service Manuals
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. RF396.pdf (240.5 KB)
