Range ignitor problems
Brand:Frigidaire
Model Number:FGGF3045RFA
Main Symptom: IGNITOR WILL NOT CLICK BY ITSELF
What happens & when: The front right burner will not light on its own. It will not even click when isolated, but when any other burner is clicking the front right burner will click and ignite. I’m contemplating the issue.
Parts or tests already tried: none
This issue will most likely be caused by a faulty ignition switch. You can test the switch for continuity. There should be continuity when the switch is turned to the lite section. If there is no continuity then the switch will need to be replaced. Here is a link to the switch harness.
https://www.appliancepartspros.com/frigidaire-harness-ignitor-316580615-ap4566012.html
