Range Hood Fan Stopped Working
Hello! I called the geniuses at kenmore and all they would tell me is that if the switch is shot I need to change it. On the other hand, if the fan motor is shot, I need to replace that. Unfortunately, they couldn’t tell me how to determine which one is broken, either the motor or the switch. Any suggestions?
Here are the parts
233.51041590
Remove power from the unit
Short the two wires going to the switch together
Tape them up if you have to, so they cannot short to the case
Reapply power
If the fan goes on the switch is shot
