Range Conversion to Natural Gas
Just purchased orifices to convert to natural gas from APP. Came marked with where they go. Problem is it appears there is none for the left rear. Part number AP3085526 (2 required) is marked left front, right, then is cut off. part AP2990579 right front, part AP8273067 right rear. I figured the the AP3085526 is for the left left rear but just wanted to be sure before I changed it. Also, how do u convert the oven portion since there is no orifice for it? Thanks much.
On the valve there is a nut type part you take off and flip over. I’m assuming this had been converted to LP prior.
Nat
Thank You Nat. The valve u are talking about is on the rear or inside the oven itself?? And again, thanks.
Is the valve ur talking about on the back of the range or in the oven itself?? And Thanks Nat…
