"Rinse Only" light keeps blinking
Rinse only light keeps blinking. I can’t cancel it so it won’t run
Have you tried removing power from the unit for a couple minutes to see if it will reset?
Either unplug it or shut the breaker off.
Yes, that’s always my first “fix”. Didn’t help
Replacement parts for WHIRLPOOL GU1500XTKQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
This may also come in handy.
Whirlpool KD-12 Point Voyager Dishwasher Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Could be a stuck key.
The usual way to troubleshoot this is to check the keypad output with a meter. If it is OK then replace the control board. If not replace the keypad.
Still a bit of a crap shoot but your odds are better.
GU1500.pdf (1.1 MB)
