"Display window blinking non-stop"
Hi guys help,
The display window will not stop blinking. When the time is on dislpay. I tried unplugging it but did not work.
Thank" Guys
Sounds like the problem is a bad clock/timer. You have to order the new overlay as well because it’s glued to the clock/timer.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FEF365BGWB Frg(v2) / Electric Range | AppliancePartsPros.com
