Quiet Partner 2 - Only Some buttons working on control panel
I have a whirlpool quiet partner 2 and only some of the rinse options are working on the control panel. The rinse only option and heavy wash option are the only ones that seem to work. The model no. is DU951PWKB1 and serial no. is FP1005544. Any help solving this problem is greatly appreciated. Thank you.
Remove the access panel at the bottom of the dishwasher and look for the tech sheet. It will tell you how to run diagnostics to test the different parts of the dishwasher. If you can not find a tech sheet let me know and I can get you one.
I found the tech sheet and tried to push the buttons in the sequence that it showed but nothing happens. This may be because on of the buttons needed to press to run the diagnostics test does not work? Do you have any suggestions to what I should try or do next?
