I purchased this unit in 2005, installed and had the first instance of stoppage about 18 months later., when the repair people came , they rebooted is, then informed me that there was a recall on the heating element and returned to replace the element, tub and pump assembly. In July of last year it quit again, this time have no power. It was the fusible link. I replaced the link 2 months later only to have it fail again in less then 90 days.
On the second replacement which took longer, it lasted 45 days, but this time on inspection there was a burnout on the control panel circuit board.it melter part of the line voltage connector on the black wire feed. As I do not have a schematic of the circuit or a wiring diagram, I have no idea what could have caused this overload.
Can you help???
Parts for Whirlpool DU1101XTPB1 Dishwasher - AppliancePartsPros.com
See the attachment for your tech sheet.
Hopefully it will help you narrow down the problem.
Itis important that when the fuse is replaced that the new wire harness that comes with it is also replaced/used.
DU1101.pdf (161.1 KB)
