Question about thermostat assembly connection
Brand: LG
Model Number: DLE2701V
Main Symptom: replacing thermostats assembly
What happens & when: replacing previous part. The old thermostat assembly has 2 prongs for wires, the new assembly has 3. Only have 1 red and white 1 wire to connect
Parts or tests already tried: part L125-31C
If you could provide the part number of the thermostat that you are replacing it will be helpful in determining if you are getting the correct part.
L125-31C. It was the same product number that was on the thermostat assembly that was removed
Do you have the part number for the thermostat. A thermostat could have the same marking but not be the same.
