Pump wine, hard water?
There is this whining that started intermittent, and gradually got worse. I found this video and its the exact same unit with the same noise.
Loud dishwasher Frigidaire Gallery mode BGHD2433KF1 - unbearable motor grinding sound - YouTube
When i put vinegar in it, the noise stops for 2-3 washes then returns.
should I use something stronger like CLR?
[quote=nick3501;683059]There is this whining that started intermittent, and gradually got worse. I found this video and its the exact same unit with the same noise.
should I use something stronger like CLR?[/quote]
Hello Nick. you have a bad AP5272381 motorand it will need to be replaced. Thank you and good luck !
