could you give some pointers on replacing the direct drive pump on this model it leaks water while running the fill and rinse thanks
Take a look at this video. You can stop at the point of removing the pump.
You console may be different then the video, but the principle is the same. Find the two screws, take them out and the console will flip up. Getting the cabinet back on correctly may take several tries and some patience, but that should be the only problem.
Good luck
YouTube - Direct Drive Washing Machine Repair Video Tutorial Watch in HIGH Quality!
