Pump replacement
My Bosch dishwasher, model number SHU33A02UC/17 is not emptying the tub after a load has gone thru the wash cycle. That said I’ve exposed the impeller at the bottom of the sump and it does not spin easily. I’m thinking the pump needs replacing. Can anyone help me with instructions for getting at the pump and changing it out. I’d like to do it without breaking anything.
The instructions are attached to the reply.
  • The part number for the drain pump is AP2802385
Drain pump removal.pdf (349.9 KB)
Gene,
Thanks for your help.
I’ve changed the pump and the first cycle I ran seemed to go okay. Now, however, it appears I’m not getting water into the machine. What do you think has gone wrong?
Ron
