Pump replacement/ Wash pump Buzzing
Dishwasher making a buzzing noise during the wash cycles. Quiet as usual during the drain cycle. Also upper spray arm seems to not be spinning. Top rack dishes are not coming as clean as they used to. Can I replace just the Motor (only costs $112) or should I replace the circulation motor and Pump Assembly (Cost $165)? Need to know how to tell if I need the whole assembly or just the Motor?
