Ptac keeps blowing breaker
My ptac air conditioner/heat pump is tripping the breaker. No burnt wires anywhere. also i received a digital switch for this unit. It originally had knobs. How hard is it to switch this control panel? something in the unit is s causing a short, but nothing is burnt.
Did you figure out the issue? I’m having the same problem.
