Procedure to get to control panel Maytag Washer MVWB765FW2
Brand: maytag
Model Number: mvwb765fw2
Main Symptom:
Error Code (if any): F5
Based on the tech sheet the F5-** error codes have to do with the lid switch and the control. Use the attached tech sheet to run diagnostics to obtain the complete four digit error code and run the diagnostics test.
techsheet-w10607408-revf.pdf (2.5 MB)
