Brand:Maytag Bravos Model Number: MVWB750WQ0 Main Symptom:Skipping areas of cycles What happens & when: Fills drum , then skips wash and rinse cycle then drains the drum
There are a few different things that might cause this. Try running the diagnostic mode and checking the codes to see what it gives you. Here’s the tech sheet with how to run diag mode:
Alright, it may just be a calibration issue. Follow the instructions on getting into diagnostic mode and activating the manual test mode on page 2. Then, on page 5 of the tech sheet it talks about the water level and pressure transducer calibration, you’re only concerned with steps 6-9 here.
Try the calibration and see if that takes care of it.
