My refrigerator is not staying cool. I cleaned the coils as well as possible, checked the fan, compressor etc, all seems ok. I opened up the back of the freezer and the internal coils were all frozen up. i defrosted and everything worked fine. Week later same problem. I think the auto defroster is bad, but i cannot find the defrost timer, etc on this fridge to save my life. Any guidance please?
On your model the defrost system is controlled by the board behind the console where you set the units temps. Below is a picture.
Is it your opinion that i have something wrong with the whole board and i will need to replace it?
How do you open up the console? I tried to get it open, but didnt know if there was a trick to it.
Is this something that is easy to replace?
Here is a tech sheet and a manual
http://www.servicematters.com/maytag_library/docs/16025629.pdf
http://www.servicematters.com/maytag_library/docs/16026956.pdf
Try to force a defrost, see the tech sheet.
If the defrost element comes on then your defrost control board is toast.
If it does not come on, the easiest way is to use a meter and check the defrost element (30 ohms approximately) and the defrost thermostat (closed, 0 ohms when frozen, note it opens just above freezing)
If both check out OK then it is probably the board or you have a bad connection. Most likely the board.
Will do. Thanks for the info and manuals. Hopefully its a pretty easy fix.
How do you know for sure if the defrost is coming on? I forced a defrost on the fridge as suggested, and i think it turned on the defrost, but i am not 100% sure. before i spend $80 on the part, is there any way to guarantee that the defrost is coming on and the issue is the circuit board? Should I unload the freezer, take off the back panel and see if i can notice the defrost working?
[COLOR=Blue]Should I unload the freezer, take off the back panel and see if i can notice the defrost working?[/COLOR]
Yes.
Do it after the unit has run for awhile. The reason is that if the defrost thermostat is not frozen the defrost heater will not come on.
The defrost thermostat opens just above freezing.
Be careful do not burn your fingers.
Denman
Sorry for the break in time. I have been doing the forced defrost (short cycle) for a few weeks now to see if i could determine the problem. I force defrost every day or couple of days and the fridge is staying cold. However, the back panel of the freezer is all frosted up and i have a feeling that the coils are a big block of ice. Does this mean that the control board is messed up or could it be that the coil heater isnt working?
Since you can force a defrost I would say that the board is toast.
Only way to tell for sure is to remove the evaporator coil cover, force a defrost and see if the heater comes on.
If it does the board is toast.
