Problem with Samsung Flex refrigerator RF23A9771SR
Brand: Samsung
Model Number: RF23A9771SR
Main Symptom: Fridge lights, compressor, fans, everything dead EXCEPT for family hub
What happens & when: Saturday night, after cleaning up from dinner I went to get something from the fridge and opened the door and noticed the interior lights didn’t come on. I tried the Flex and freezer doors too and nothing. But the Family hub was still working.
Error Code (if any): Error 41
I unplugged the fridge. Waited 20 mins, plugged back in. The family hub booted but the rest of the fridge still didn’t do anything (no lights, no compressor no fans)
I unplugged again, pulled fridge out and opened the main board cover to see for LEDs. With cover off I plugged fridge back in. Family hun came back, but still nothing else. I noticed the red LED was flashing. But not a pattern. Just flashing repeatedly. I listened very closely and noticed there saw a VERY faint clicking sound too. NOT a relay clicking but perhaps from one of the components on the board itself.
I decided to unplug and plug back in one more time and observe the board. When I plugged back in, again the family hub came back but nothing else. The LED started flashing again but suddenly the top left of the board popped loud and burnt up with smoke. I unplugged the fridge and didn’t plug it back in.
In the link you can see pics of what burned on the board.
I’m not sure if it was just a components on the main board that fatigued and burned or what. Since I test every components I could think of downstream from it:
-I pulled off the fridge back wall to expose the evaporator and associated sensors and fans. I tested each sensor for correct resistance. I tested the fan with my DC power source and measured current, all checked out. The fan feedback wire also checked out in terms of it not shorting out. I tested the damper motor - similarly all good.
-I pulled off the back walls of both the flex and freezer compartments, tested the fans and sensors all was good
-I pulled out the ice makers (big and small cubes), tested their motors and verified the hall sensors and made sure there were no shorts.
-I pulled off the family hub display to see and check for any burn marks there but didn’t notice anything and didn’t spend too much time there because that was the only component working.
-I tested the condenser fan next to the compressor also, same thing - worked perfectly.
-As far as I could tell, there was no ICE buildup anywhere. Though I did get to these tests about 7 hours after the fridge died.
-I checked under the wire harness cover under both the left and right door hinges and all wires were ok, no sign of burns, stress, pinches.
At this point I’m not sure what else to do but replace the main board. The main concern is, what if it was a downstream component and it burns up the new main board also?
When I first bought the fridge while under warranty, the wifi module went out - they came and replaced the entire family hub. I should have looked closer to see where the wifi module was; I couldn’t find it during my recent attempt. Is it possible that module caused a short?
Any help from the community would be greatly appreciated.
Photos / video link: https://photos.app.goo.gl/dHq9NZmiA3KKuNme7
With this issue, it would be a communication issue and would require a new control board. Here is a link to the part number.
https://www.appliancepartspros.com/samsung-assy-pcb-eeprom-da94-05316c-ap7188942.html
I was unsure if the board could just up and meltdown by itself.
Apparently that was just it - though i did gain a ton of experience taking the entire fridge apart looking for a gremlin!
New board fixed the issue. Thank you!
