The “start” switch of my dryer moved into the backsplash area due to a broken peice of plastic. When I was opening the backsplash, the power cable was still connected and the start switch feel into the metallic portion of backsplash with a small popping sound and a small portion of the metal turned black. Now I see that the dryer does not start when I try to manually turn the start switch.
- I’d appreciate if anyone can let me know if they ran into this kind of issue before what they did to address the problem.
- Should I try ordering a new start switch (assuming that the previous one short circuited) and will that fix the issue or could there be something else that could get damaged as a result of this short circuit?
- Is there anything else that need to be done apart from changing the start swictch - like resetting or replacing a fuse?
Thanks in advance.
