Problem with my oven door not closing
I have a Frigidaire stove with the oven door that will not close. The left side of the door has a better chance of closing, but the right side is open about 1" - 2" and will not close at all. I’m wondering if the hinge in the stove is bad, and not too sure if the hinge in the door is actually bad. Love hearing from someone on this subject. It almost seems light an alignment problem. Anyway love hearing from anyone that has any good ideas on this subject.
Roger
Hi.
Pull the door off the hinges and try the hinges without it.
Most likely it’s the hinges.
The right side AP4433366
The left side AP4452365
here are the breakdown diagrams and Replacement parts for Frigidaire FEF352AWD Frigidaire/electric Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
