Problem with my ice maker flapper door
Brand: Electrolux
Model Number: EI26SS55GS0
Main Symptom: It is not dispensing ice because the flapper door does not open. When you press the switch, you hear a clicking sound, but it does not open. I tested in tech mode, and it pushes the ice to the flapper, but it does not open. Do I need to replace the whole dispenser module, or is the problem something else?
That’s going to be a problem with the dispenser module 241753401. Sometimes the linkage to the flapper door comes loose, so you might be able to remove the dispenser module and slot that linkage back in place, but otherwise the module will need to be replaced.
Thank you for your fast reply.
Could you send me how to disassemble it without braking any plastic part.
Or the service Manual for this component.
I hope for your prompt responces.
Thank you,
The entire service manual is too large to upload here, but I’ve attached the relevant pages below.
Document-EI26SS55GS0.pdf (1.3 MB)
