Problem with my drain pump?
Hi… I have a problem with my dishwasher !!! When my wash is finish.. my drain pump start for out the water in the dishwater !!!
But … my drain pump work around 5 minutes when all water is out !!! and the drain pump make a wrong sound.. because don’t have water in the pump !!!
I bought a new pump.. !!! and I have always this problem !!!
What’s stop the drain pump.. !! Is it a timer, electronic switch, float valve …???
Sorry for my english.. I speak french !! And thanks youi for your help !!!
[quote=alexandre1733;290797]Hi… I have a problem with my dishwasher !!! When my wash is finish.. my drain pump start for out the water in the dishwater !!!
Sorry for my english.. I speak french !! And thanks youi for your help !!![/quote]
Alexandre,
As best I can tell, there was a noise in the drain pump, you replaced the pump and the noise is still there ?
And you have had the noise from the pump, since you’ve had the machine ?
The component that controls the drain pump, is the electronic control board,
AP6013336
Is your complaint, the pump does not turn off ?
AP6010255
You may want to check and make sure the unit is installed properly.
especially the drain hose routing and possible electrical conduit shorted to the drain pump wires/terminals.
:confused: :confused: :confused:
[quote=Joe / APP Team;290822]Alexandre,
:confused: :confused: :confused:[/quote]
I have the noise since around 6 month - 1 year and my dishwasher it’s a 5 years old !!!
I changed the drain pump.. but I have always this noise… It’s not the drain pump the problem…
The drain pump work very good.. But.. what’s say to the drain pump -STOP- NO WATER in the dishwasher !!! is it a timer or probe ???
Because… when the wash is finish… the drain pump start and go out the water.. but when the dishwasher is empty (water) the pump work for around 5 minutes… with no water… and the pump make a noise !!!
thanks
[quote=alexandre1733;290842]I have the noise since around 6 month - 1 year and my dishwasher it’s a 5 years old !!!
thanks[/quote]
I’ve attached a copy of the Technical Data Sheet, so you can run a variety of tests and determine where the problem may be.
Hopefully we will be able to communicate better, and get your problem solved.
Tech Sheet - 8564549.pdf (170.1 KB)
