Problem with Maytag oven heating up after replacing part
Oven popped and smoked and control panel/display went blank, oven part would not work. I replaced the control panel. Panel now lights up but there seems to a problem with the oven heating. Takes about 1/2 hour to get to about 175…Any ideas??? Much appreciated.:confused:
Model MER5755QAQ
Here is a service manual etc.
http://www.servicematters.com/maytag_library/docs/16025644.pdf
http://www.servicematters.com/maytag_library/docs/16025646.pdf
http://www.servicematters.com/maytag_library/docs/TDC-0065-B.pdf
Check that both broil and bake elements are OK
Check to be sure unit is in Fahrenheit
Check power going into the unit. If it is bad the stove top elements also heat slowly.
Check the actual oven temp with an in stove thermometer
  • I tried the Broiler on HI and it gets very hot - works as normal
  • The stove top eyes work perfect and heat quickly.
  • I am not sure about the oven being in Farenheit
Would the control panel and Bake Element both have gone out. But is seems weird that the Broil still works? Any insight would be appreciated. Thanks
[COLOR=Blue]Would the control panel and Bake Element both have gone out. [/COLOR]
The bake element may have blown, it might have produced a voltage spike and this may have taken out the control panel.
Thank You. I guess I will move on an order a new Bake Element and hope that does it. Thanks
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Wow, I am having the exact same problem with my Amana AER5715QAQ. Last weekend my wife was making brownies, there’s a loud buzz, the lights dim a little and then nothing. Check the stove and the bottom of the oven is glowing red, there’s a small amount of smoke in the oven and clock is burned out. Stove top works.
So Monday I installed a new clock display and today I come home to my wife complaining that she’s trying to warm the oven to 350 and it had been stuck at 155 for 15 minutes. Broil is nice and hot, checked and I’m in F degrees.
I’ll check the sticky on voltage meters, I hope my analog needle sweep works. But it sure sounds like a new heating element for the lower level is needed. At least it’s significantly cheaper than the clock display. Thank you to everyone that helped this person (and me) with their problem.
I just took the bottom off and checked the Bake Element. It is burnt through in one spot. My thought is that the Bake Element burned up and that killed the Control Panel. So I am off to order a new Bake Element and hope that finally fixes it.
I found the same thing too. Removed the bottom and found the element completely burned through at rear right. Looks pretty simple to replace. There are 2 spade terminals that need to be pulled off at the back of the stove. Let me know if you aren’t sure what I’m talking about and I’ll let you know how mine looks. Good Luck to Ya. Thanks also Denman, you were spot on with the voltage spike taking out the clock display.
