pressure switch for water control level
Researching the problem. Think it’s the pressure switch. 1st started out overfilled the tub. now it will not fill on the wash or rinse cycle without holding the water control level knob to “reset”. Is this the switch and not the pressure tubing that connects between the base of the tub and the pressure switch. I just want to make sure that’s the problem before buying the part. any ideas or info please?
I would pull the plastic hose off the water level switch and blow in it. If it seems clogged, force some vinegar down it with a turkey baster, will dissolve soap residue.
Thanks! It worked. Met resistance with blowing on the tube. used to turkey baster to force the vinegar while doing that, i heard it “Pop” open and then the vinegar flowed in!! You saved us 50+ dollars!!!
