Pressure Sensor Adjustment
Hello
I just bought a GE GFWS2600F1WW front load washer and I want to adjust the amount of water it puts in the drum. It’s just not enough. Clothes will go thru a whole cycle and some come out bone dry..I have read that you can adjust the pressure sensor but I am not sure if this one is adjustable. The pressure sensor part number is WH12X10595. Does anyone know if you can and How to adjust this sensor. Thanks for your help. Tim
I always replace these, if this part fails then you can have a terrible flood.
[QUOTE=sidfink43;892731]I always replace these, if this part fails then you can have a terrible flood.[/QUOTE]
Absolute truth here always replace. Most now are analog and are non adjustable.
