Powers up, drum won't turn & makes buzzing sound
My dryer is a little over 3 years old. It turns on, but makes an electrical buzzing sound when you push the start button, and it doesn’t ever start. Nothing is jammed and everything has been vacuumed out. The belt is on, and the drum will turn if you start it by hand. Please help!!!
If wha you are saying is the dryer starts up and operating if you start the drum by hand then the problem is your motor has failed and will need to b replaced.
AP6029874
