Power to igniters (no glow)
Brand: Samsung
Model Number: Nx58k9850ss
Main Symptom: no power to igniters (no glow)
What happens & when: both the broil and the bake igniters are not glowing and I was wondering if it would be a main board relay issue and not a safety valve because the surface burners are working just fine
If the back of the range is accessed, and the gas supply turned off, the bake igniter can be tested for 120 Volts AC when the oven is set to a bake cycle. With a meter set to Volts AC and each probe set to a different wire at the igniter connection, does 120 Volts show up? If not, what about if one meter probe is placed on the metal frame of the range? If there still is not voltage, with the power cord unplugged and the oven sensor wire disconnected, does the oven sensor measure a resistance close to 1100 Ohms?
