Brand:GE Model Number:JT5000BL5TS Main Symptom:was preheating when it shut off and this came on screen , ]]. [[ What happens & when: now the screen is blank and will not reset after breaker turned off for 30 minutes.
Error Code (if any): ] ]. [[
Parts or tests already tried: how canitest if the control board is bad ?
or your GE wall oven model JT5000BL5TS1, a great first step is to check the oven’s stored fault history. This can often provide valuable clues about what’s causing the issue.
Try the following:
Press and hold the 1 and 5 keys at the same time for about 3 seconds until “tESt” appears on the display.
Press Steam Clean to scroll through any stored fault codes (F-codes).
Write down any codes that appear, including multiple codes if more than one is stored.
Press Cancel/Off to exit diagnostic mode.
A couple of things to keep in mind:
GE has used different control boards over the years, so if pressing 1 + 5 doesn’t bring up “tESt”, your oven may use a different method to enter diagnostics.
The exact fault code is very important. Codes such as F2, F7, F9, and others can help identify whether the problem is related to the temperature sensor, keypad, door lock system, wiring, or the electronic control board.
Once you have the fault code(s), feel free to share them and we’ll be happy to help interpret what they mean and suggest the next troubleshooting steps.
