The posts & pans light blinks rapidly. Unit will not wash or otherwise function.
Cause? Cure?
Most likely the problem is a stuck pad on the key panel.
In order to provide the right part number for the console I need the color of the dishwasher.
From bothellboy’s email:
“It is a stainless steel unit. I turned off the power, then turned it back on, and now two lights are on (not blinking), the pots & pans light, and the heated dry light.”
[COLOR=gray]Admin note: Please reply here. Do not reply via e-mail.[/COLOR]
