Brand:Samsung Model Number:NX60/A6511SS-AA00 Main Symptom: possessed Samsung range What happens & when: sooo, it all started when Samsung tech came out and said my oven was shorted out by roaches (I have an exterminator) Ive fired them. So…I ordered and replaced the main electronic board, and because that did not fix the oven not turning on, nor the display working, I have ordered and installed a new display. Now, when you press any funtion, Bake, says broil, broil says proof, none of the buttons work correctly. Also if you hit start, it says door. So I took the broiler door all the way off, and put it back, nope. so I am guessing wiring issue? like at this point I could have gone got a cheap oven some place as all I actually do is use the bake option and the stove top. Any help is appreciated.
In a case of insect infestation you could have damage to any or all control boards that ere affected, and may have to replace them all. The wiring could be an issue as well, recheck all the wiring for damages, loose connections…etc.
We have Already replaced the electronic board, the display module, now the problem is that the functions do not work correctly. We took it back apart and everything was replaced correctly. we took a picture of it prior to removing the old one so we would know how to put the new one in. So..If you press bake and then start, it says broil and Door, so it thinks the door is not closed. which is not the case. At this point I’m considering finding it a new home and looking for a simple stove that turns on and off.
