Pooling Water IN Dishwasher Pan after cycle
Brand:KitchenAid
**Model Number:**KUDP02CRBS1
Main Symptom: Water in pan
What happens & when: Finding water in the bottom of the pan after wash cycle. Checked all hoses to ensure no blockage, raised Hose above Disposal connect to prevent backflow.Cleaned out Filter area too. Can a bad Inlet Value Cause water to remain in the dishwasher pan? If it is the Inlet Valve what part # would I need for the Above mentioned model KUDP02CRBS1? Thank You !!
Error Code (if any): None
Parts or tests already tried: See above
Is the water pooling up above the filter screen or is it below the filter screen? Also, how much water pools up in either case?
The water is above the Filter screen and fills the whole bottom pan area. I have turned off the water supply line and now there is no water there, completely dry. Also after numerous threads that I have read it appears that it is the Water Inlet Valve. I did order this valve from your company on the 6th, awaiting shipping notification. Thank you
It definitely sounds like the valve has failed.
Thanks William, have a great day
