Please help lots of water from frigidaire affinity washer
So my drain pump went out in my front loader washing machine. We bought a new one and replaced it. It is draining fine, but now when washing machine fills for wash cycle it doesnt stop…just keeps filling up, and water is massivly pouring from somewhere out the bottom…ALOT of water. As i watched it spin to get the excess water out of the tub, it seems like maybe the tub got unbalanced somehow? Could that be why the water is pouring out of the bottom? It only pours out during filling of the washer. Not draining or spinning. I did the push start and cancel at the same time and it gave me a error 11 code. Which is water inlet…could that part be bad? Or could it be something we did while replacing the drain pump. Any ideas are appreciated! Thanks so much for your time!
Yeah, I would replace the valve assembly and see if that fixes things. If you buy from this site you can return it if does not fix the problem.
